Careful not to cut into the tub. You may have better luck with a hacksaw blade. Cut a slit in it then insert a cold chisel in the slip and rap it in the direction you would to unscrew it (counterclockwise) and it should loosen up. You could start with some WD-40 or penetrating oil.
Barry
