I have a 3"-4" radiator pipe with a T fitting that has a 1 1/4" fitting coming off the T. Well I was in the process of moving a radiator and I was really cranking on the pipe. Sure thing I broke a piece of the threading off from the 1 1/4" T. 3/4s of the threading are still intact. The system is for hot water heat. So my question is can I weld a fitting in place? Some people have suggested JB weld. Any suggestions are much appreciated. Removing the large T fitting is pretty much out of the question due to its location in the pipe system. Thank you.
