I have a broken pipe under the cement, it comes from the main floor to the basment where it then is under the cement out to a 4" pipe at the bottom of a stair well. water remains in the 4" pipe about 18 inches down... I would assume that the pipe from inside would enter above this water line correct??? now my solution would be to break the cement next to the 4" pipe towards the house, then remove broken pipe replace with pcv pipe gravel then new cement? correct? I would assume that the old pipe is below the cement and not with in it correct?
thanks homeowner with a major water problem....
thanks
simon
thanks
simon
