1 - 18 of 18 Posts
i was pulling a 250 ft run when my nightmare started now i have about 125 ft of coaxl and cat5 cable in my conduit which is underground i was using mule tape my hope is i can pour something into the conduit ti disolve the mule tape so i can back the wire back outany ideas
Discussion Starter · #9 ·
dont think bundle is to big. i could take all wires and slide the into pipe . i dont know. all i do know is tape did snap and is in pipe and i cannot pull it out from end it started from without breaking cable into.i hope if i can disolve tape i may be able to pull wire out of pipe .but i dont know what will disolve the tape
I can't imagine a solvent that would dissolve mule tape (likely PE) without damaging the good stuff in there. Not sure if you could pump in some water/soap mixture to get it lubed a bit, pull it all out, then blow out emt to dry it and start over. Likely emt is too narrow for cables being inserted so you'll likely need fewer cables or a bigger pipe IMO.
Mule tape is made from polyester fibres. I doubt you'll find anything to dissolve it that won't cause damage to everything else. A ball of Mule Tape is actually quite slippery, however it could be snagged in the conduit. I think digging is your only option.
Discussion Starter · #15 ·
it is about 237 ft is my best estimate.cant really say as i didnt put it in but i hope it only has 2 90's in it and may they be long sweeps but i dont know for sure but it is riged.im on my way back to job site to try to put air to it and try to blow it back as i pull on it .i appreciate any suggestions
1 - 18 of 18 Posts
