I am replacing outlets and rerouting some cables on a circuit that is giving me fits with old Romex 12/3 copper wires that are broken. The whole room was wired wIth switched outlets which look pretty old and I don’t need. So far I have opened two outlet boxes that were overstuffed full (they used pigtails for everything including ground) and in both boxes a ground wire was snapped off. It’s possible I snapped it when pulling everything out of the box. I also found one black wire that feels like it’s snapped under the insulation. They were in a wall that’s open so I replaced with bigger boxes and ran new 12/2 romex which worked out better.
Anyway, my two questions are:
1. No heat in the house while I’m working. It’s about 40-45 degrees in there. Do the overstuffed copper cables get more brittle when being bent and yanked in the cold? Would I be smarter to get a heater to avoid working on cold copper?
2. Since these are only the first 2 receptacles that were wired like this on the circuit, and I have 6 more to go, should I give up on keeping the 12/3 cable that feeds all these and rewire the whole thing? I don’t need the extra hot wire and now I’m wondering if this old cable is too old to re use.
