Sound like an idea. I was also perhaps thinking of maybe two metal straps or a larger outlet perhaps.I would drill new holes in the corners of the box into the wall and use tapcon crews.
Thanks , I'm not really fussed about matching the texture. The outlet is outside in the Lanai area.sprayed-on coating over block ? to 'finish' use plastic grocery store bags scrunched up into a wad,,, nothing will come as close to the original texture
Yes, I was thinking a couple of straps on the outside, won't look right that's for sure but will keep it in place is my thinking. Or an outlet that has screws on the outside corners if they make one?Ayuh,.... A couple of straps, with the tap-cons outside the box,..??
Hyd. grout mixed to a paste consistency can be packed into the failed concrete areas to restore the flatness of what's there,.....
That's how I would fix it, after scraping off all the loose stuff.Anything wrong with some construction adhesive?
Thanks , got any brand names of the adhesive I can look into please?That's how I would fix it, after scraping off all the loose stuff.
Push something heavy against the box to keep it in place while the adhesive dries and you're good to go, Limey.
