1 - 13 of 13 Posts
I'm plumbing my basement bath. The 2" vent pipes will run inside a 2x4 framed wall on the outside wall of the basement....therefore, I'll need to dig out the concrete in a couple of spaces relatively close to the foundation-about 2 inches off the wall. The concrete appears to be approximately 6" in these places.
Is it OK to notch out the concrete in a couple of places that close to the foundation walls so that I can run the pipes from under the ground up inside the wall?
based o your dimensions, you'd probably be ok as the foundation should be at least 16" wide x 12" tall,,, i'd feel much better if you diamond core-drill'd the holes but, if you're careful, using a 4" grinder & diamond blade'll make quick work of the task,,, careful w/the chipping gun, too !.
' outside wall of the basement ' is still inside, right ? what's the 6" measurement - the thickness of the foundation ? most modern footers have 2 lengths of # 4rebar in the conc footer but doesn't necessarily mean yours does :huh:
Yes, inside the basement near the concrete wall. Here is a picture to give a better Idea. I'm going to frame a wall on the side where the window is. I will need to run 3 2" vent pipes up from the ground into that wall. I've broken out the patch work that was already there, but need to get closer to the wall for the vent pipes. the 6 inches was an estimate of how thick the concrete is where I need to break it out to get closer to the wall---it could be 8", but I'm not sure if that is the thickness of the floor or I've hit the footer...
Basically I need to do what the person before me did for that copper vent pipe...but not sure if I'm allowed/should.
you live in pa, right ? somewhere between easton & philly ?
allowed ? of course you're allowed - its your home, isn't it ?,,, just remember the shame of calling a plumber to repair YOUR f/u will soon be spread about town :thumbup: don't ask me how i know - i just know :laughing:
No, I live on Long Island. Haha. Fortunately I have a plumber friend of mine coming to help me do the plumbing work, but I have to get everything ready, including digging and framing the walls.
I know I'm "allowed" but am I going to f :censored: anything up? That may be rhetorical haha, but am I going to mess up the foundation or anything by doing so?
Discussion Starter · #9 ·
Why do you need to move it closer to the wall?
I don't need to move it closer to the wall, but I'm properly venting the fixtures and my vent pipes will need to run up inside the 2x4 framed wall I will be building. That particular copper pipe will be removed and three vent pipes, one from each fixture will run up inside the wall. Therefore, I need to run up from the concrete floor through the sill plate of the wall. The sill plate will start about 2 inches off the wall---
Master General ReEngineer
Ayuh,.... Even though copper through concrete ain't the greatest idea, it's there...
Just hammer out that pipe, 'n enlarge that hole wide enough to accomidate the pipes yer puttin' in...
That little hole, even 3 times bigger, ain't gonna cause the house to keel over or nothin'...
Discussion Starter · #13 ·
Your basement slab "should" be independent of the wall footer (foundation) Unless you are digging out a foot of material below the 4" slab you will be fine.
Definitely not digging anywhere near a foot down--but I'm beginning to realize that "should" is a very operative word when dealing with a 90 year old house.
1 - 13 of 13 Posts
