Last night while using a microwave + toaster oven on the same circuit in the kitchen, we managed to trip the breaker. I found the tripped breaker and turned it back on, but the sockets still weren't working. Also, for some reason, the breaker above won't go all the way to the off position, and switching it on doesn't turn on it's respective circuit.
I have attached pictures of the breaker box. This is the first time I am attempting to muck around with the electrical, so I wanted to get any feedback before I hurt myself! I'm an electrical engineer, so debugging electrical issues is not exactly new territory, but that obviously has limited application when dealing with the house.
I was planning on shutting off power to the panel and then checking continuity through the breaker. Is this a good start to find out if the breaker is faulty? If that checks out, I was going to measure the AC voltage directly on the breaker bolt. So...
1. Any suggestions?
2. Anyone know this type of breaker? I think it starts with a Z, and they are notoriously bad for not tripping when they are supposed to (according to the home inspector)
PS: In the picture, the 2nd from the top breaker is what was tripped when I checked the panel. For some reason, the top one is now stuck in that position (won't go off), and turning the 2nd one on doesn't turn on their respective sockets)
1. Any suggestions?
