I am hoping I can get some help on a breaker that keeps tripping. In my garage I recently added two dedicated 20amp outlets and a 220 outlet for a welder. The breaker box is literally right above the outlets and the run is about two feet. I used 12 gauge wire on the 20 amp outlets and 6 gauge for the welder. When I plug my 7.5 amp compressor into the right outlet and turn it on it immediately trips the breaker. When I plug it in the left side it works great. Other smaller items like my radio, vacuum, battery charger etc all work fine in the right outlet, just not the compressor.
Here's what I'm looking at...
I replaced the breaker thinking maybe it was weak or something but the new breaker is doing the same thing.... left side works great, right side works great for everything but the compressor. I put an amp meter on the right side and set it to "MAX" to capture the highest amp reading but it trips so fast I can't even get a reading. The only thing I haven't done is replaced the outlet because I just don't have a 20 amp outlet at my fingertips right now. I'm just looking for some advice on where to look for the problem.
Thanks in advance.
Thanks in advance.
