I have a residential built in oven (or actually my son is doing the install). Three phase (220) setup, RST N and Earth, total of 380 volts +/-. The oven is actually segregated, three parts, each using a phase of 220 volt, there are no actually 380 volt components.
The electrician gave him five different colored wires (10 awg) in the dedicated oven wall outlet, us thinking it was a standard three phase setup. But after checking, they are actually three 220 volt wires, same phase, fused (16 amp) separate breakers, there is actually only a single phase (220) available in the house. Scratch my head, now why and the heck did the electrician do that?
My first impulse was to hook up a single wire with a bridge (in the installation kit) in the oven, along with neutral and ground and call it good. But then decided to hook up all three wires (fused separately) with a common neutral. Got to thinking later that the oven may be over fused, I sure don't know how the fuses will react, fused in parallel. Any thoughts?
