I installed a new faucet in the bathroom, as the old one had a leak, seemed it might have cracked inside somehow, as it wasn't cartridges or o-ring or anything.
Anyway, I noticed one of the braided flex hoses was leaking a bit, so I thought I would change both of those while I was at it.
So, I have PEX coming into a shutoff, both of which were not leaking in any way while I had everything off, then the 12" braided steel flex hose going to the faucet.
Everything is re-installed, but for some reason the cold water flex hose, but not the hot, keeps leaking around the nuts. I definitely hand tightened them, and then did another quarter turn, and it leaked at both ends, maybe 5 or 6 drops worth that I could wick off with a tissue when I ran the water for 3 or 4 minutes. So, I tightened both ends a bit more, and a bit more, experimenting if there was still a bit of water. I don't want to tighten them any more, as I'm worried they are already over-tight, but I can't see how to make them stop leaking. Right now there is not a lot of water. A little gathers around the nut, and it only makes a little water spot on a tissue, but still, I would think these should be water tight, should they not?
I can't see how to prevent this. Not sure that putting a new shut off, and trying my luck with a different brand hose would work. Shouldn't be an issue with the faucet as it is new, so that connection is new faucet to new hose, and should be clean. Do I have to over tighten these?
