1 - 18 of 18 Posts
]I got the panel bonded with screw(1 1/2 "green one did not work-too short) and also used a jumper to neutral bar for double bond..
Does it matter that the green one is not used?
Also grounded aluminum to copper pipe
with anti corrosion on the aluminum(not on the copper pipe). Hand Finger Metal Fashion accessory
Electrical wiring Cable management Wire Cable Technology
Cable management Electrical wiring Wire Technology Cable
· Lic Electrical Inspector
Is the ground clamp listed for AL conductors? IS the mounting screw for the lug a machine screw?
When looking at them they all said either for copper only .. or... for Al only (didnt have "FOR BOTH" )and i have a big copper pipe..didnt see one for both in a main electric supply store-only online.
I have applied the NOALOX to the aluminum.Before contact w copper.
Id rather it be inserted at the smaller area with the smaller clamp-on it seperate- than have to use a larger amount of it on the AL clamp when its in contact with the large copper pipe.
That pipe clamp is for use with armored copper ground wire.
You should get a clamp made of zinc die-cast metal which could be used for either copper or aluminum wire. Here is one from Arlington, cat #720Z:
The clamp is listed for use for a GEC with or without armor. I question whether it is listed for AL. The packaging should indicate if it approved for use with AL.
No-Ox is not needed. The small saddle clamp is used for bonding the metallic armor of the GEC if present which in your case is not. I'm still questioning the screw you used to mount the lug to the panel. It it a self tapper?
This picture kind of shows how the saddle clamp works;
hidden1 said:
Brass for copper connections..(no AL)
Odd that a local electricians supplier wouldnt have it if it were NEC required..
So many older homes still use/need these..
It has nothing to do with material the clamp is made of. It depends on what the clamp is listed for. Somewhere on the clamp it should indicate what it is listed for. Such as AL only, or CU only or AL CU. check the clamp for what it is listed for. Happy Thanksgiving!!
· UAW SKILLED TRADES
In argeement with Electures ... that clamp is not for aluminum wire . Try Burndy pipe grounding clamps they have always been my choice.
What is marked / stamped / embossed / raised lettering - on the clamp itself?
hidden1 said:
This is crazy but the exact same clamp i have(yes same item# too) on earlier pic that you say wont work on AL-online says Al on it..
I take it i CAN use this after all?
Yes. Good to go.
1 - 18 of 18 Posts
