Hi there!
I have a problem restoring an antique French cast iron wood stove.
As I was derusting it, one of the feet broke loose.
It's the part that was holding it to the body that broke. I guess it's a bold but I am not sure. The reason I am not sure is specifically because I am having a terrible time removing that "bold" to replace it.
Here is a video that describes it:
IMG_9261.MOV
I have applied old gasoline on it and let it react for a day, many days in a row. I have tried turning the "screwhead" with a screwdriver, it won't budge. I have filed the part that is stuck in the stove's body to make it flat and tried to turn it with a clamp, to no avail.
The thing that strikes me is that I don't see any "boundary" between what should be the bolt, and the "hole" in which it is supposed to screw. Neither on the stove's body nor on the foot. It looks blended into the "hole", as if it had been welded. I would be very surprised if it was indeed welded in the past, for 2 reasons. First because I wouldn't see the benefit of doing that. Second because I don't see how on Earth one would have managed to do it with the foot in position.
In the video I have already filed around the "bolt", because I was hoping to remove that little "mountain" around it. I removed most of it all right, but it still looks as if it had been welded.
Would anyone have any idea how I could remove the remnants of this "bolt", without damaging the stove any more? Or an alternative solution to getting the foot back into place?
Thanks a lot in advance for your help!
