1 - 6 of 6 Posts
I'm doing some research for the upcoming replacement of my 40 gallon natural gas water heater which is aging.
I've had very good experience with indirect-fired heaters in the past, but those have been installed in combination with large oil-fired boilers that have plenty of capacity.
The boiler is a small natural gas fired Weil-McLain CGA-25, with an input rating of 52,000 Btuh and output of 44,000 Btuh.
I would be interested in keeping a 35-40 gallon storage capacity. It's just the two of us. One bathroom, 10 minute showers, no dishwasher, a couple loads of laundry per week. I can't remember the last time the shower got cold.
I like the idea of one less opening in the flue (these are naturally drafted), and the storage capacity for when the power is out. I don't like the idea of tankless heaters with flow switches, electronics and drilling holes in the side of the house for PVC venting.
I figure if my natural gas water heater has an input of 38,000 btuh, my boiler should be able to at least match it's performance. I would likely need to have a the indirect zone set for priority, however.
Think this would work?
Thanks, but my issue with a natural draft replacement stems from venting. Draft is an issue and I have insulation work on hold because of it.
An indirect fired heater would allow me to eliminate an opening into the flue, which should assist with draft. The original boiler was much larger and oil-fired and had much hotter stack temps with higher buoyancy.
1 - 6 of 6 Posts
