hello.
i have a standard hot boiler water heater, and recently, i noticed that the relief valve will spill out some water (not excessive, may be half a pint of water) each time when the thermostat finished calling for heat. The water that comes out are very hot as i can see the steam from the water while its spilling onto the floor.
in other words, when the fire of the boiler seems to be stopping, then the water will come out from the relief valve.
I have googled a bit, and found usually leaks from relief valve is constant, and not after thermostat finished calling for heat. The expansion tank was replaced about 3 years ago. I am guessing its either the relief valve or the expansion tank itself.
however, would like to seek some opinion before replacing these parts.
Thanks
Thanks
