What is the best way to board up windows on a Stucco house? I've seen some houses that have studs sticking out of the stucco so that you could attach plywood & a wing nut but don't like the way it looks.
Is this a permanent closure or temporary? It would help is the post was a little more detailed as to what you want and why.What is the best way to board up windows on a Stucco house? I've seen some houses that have studs sticking out of the stucco so that you could attach plywood & a wing nut but don't like the way it looks.
Temporary if needed for Hurrican season here in South Texas. I will only board up if we are going to get hit by one of them & just want to be prepaired.Is this a permanent closure or temporary? It would help is the post was a little more detailed as to what you want and why.
Ron
They won't work on Stucco."Plylox" window clips.
I think the two problems experienced with using them on stucco returns has been, first of all, the fact that most older stucco returns (here in Florida, anyway) are not 90 degrees. Many of the window openings tend to bevel outward. This all but defeats the Plyloc design function.They won't work on Stucco.
