Yesterday I came home to realize my house was freezing. I went down to the furnace and pulled the cover off. I manually pressed the safety switch which resulted in an immediately call for heat. The ignitors lit no problem. I realized the blower fan wheel was spinning slow and after hearing my furnace cycle off and on over a million times through the years, noticed that the blower wasn't ramping up enough to blow any air. After about 1 min. the furnace diagnoses a problem and cycles off. So today I call the HVAC company that installed my furnace (9 years ago) to come have a look. My wife was home and the tech told her the AC coil was completely plugged. She called and told me this and told me the tech gave her instructions to give to me. SO I call the tech and told him that yes, my AC coil may be plugged up, and I will clean it, but this isn't the problem. There is something wrong with the blower. He assured me there wasn't anything wrong with it. So I get home from work, remove the coil, clean it gently with a toothbrush and re-installed it. Turn the furnace on....... SAME ISSUE. The blower is not spooling up enough to blow air. All this after I was charged $129 for him just to show up.
Any suggestions of what this could be?
Thanks
Thanks
