If the shaft is too long, you have to cut it, and a hack saw or sawzall works good for that.
On your blower choice, the replacement is a weaker motor, and won't move as much air, if the A/C is on high speed.
I try to stay closer on the fan motors. meaning I would use a 1/6 instead of a 1/4 HP motor generally. Your amp draw is very close tough, and probably won't give you a problem.
