1 - 6 of 6 Posts
I was called out to a moble home that the blower motor stopped running. I went to the force air furnace unit and jumper it to start the blower motor and it started to hum. So I check the Run Capacitor and it was good. So I took of the Blower assembly out and took it to the shop. I wired it up to check it and it worked great in all speeds. So I brought it back and hooked it up and it did the same thing....Hum. Thought it might be the fan relay so i by passed it and it did the same thing. Then I wired it up again to plug it in to a wall plug other then the dedicated circuit for the Air Handler the same thing happen. Then I went to the Moble home next door and plug it in there and it ran fine. The outside 220v compressor works fine so I know there is no problem there. I check all the connections in the panel box to make sure they are tight and they were. Could it be a bad neutral coming from the utility company to when I switch the blower motor on it drops out just enough to make it not start? The strange thing is why it works everywhere but in the home.
Banned
God does not like electrician working on furnace:laughing::eek: J/K guy.
You check the voltage of the fan supply? Sounds like a voltage drop to me.
Banned
High resistance upstream? Load the wiring at the (120v?) blower end with a 10A 120v hairdryer. 20' of #14 copper wire should cause a drop of ~ 1v.
Using the method I found a 0.5 v drop across a wirenut that was barely holding its 3 wires. When I removed the wirenut the stripped end of the wires that were in it were still straight, rather than having some twist in them. This implies a very small contact surface area.
What I missed was an outlet upstream with somewhat loose screws, because I didn't have a helper pushing on this outlet while I watched what the hair dryer did.
BTW, good relay contacts that are closed will have less than 30 mV across them at rated current. Bad, >100 mV.
Banned
Jeeze yoyzie...you sure love your numbers:eek:
Ur Momma'!
". . .when you can measure what you are speaking about, and express it in numbers, you know something about it. . ." :thumbsup:
I guess I and the taxpayer paid good money for me to learn numbers, so I'm trying to get my and their money's worth.
One of these days I'll find a real job.
Banned
Ur Momma'!
I got ur Daddy first:laughing:
1 - 6 of 6 Posts
