I built a 24'x24' garage with a bonus room above.
This includes 19 24' wood I beam joists without any additional center support.
The joists have 3 1/2" flanges, are 11 7/8 deep, and are placed 16" OCI.
The bonus room is a bit too "bouncy," so I am considering two options -- or both.
1. Running dryway perpendicular to joists to create the garage "ceiling" (also considering 3/4" plywood but concerned about the weight this will cause to the ceiling/floor).
2. Two (or more) rows of blocking at 8' and 16'.
A few questions:
1. Blocking: since each "cavity" is approximately 11 7/8" deep X 12 1/2" wide (to the edge of the flanges -- not to the web), should the size of each block be this size too? Thus, there would be 5 points of contact: screw and glue block to bottom flanges (2), screw and glue to top flanges (2), and glue block to above subfloor (1). This leaves gaps on either side of the block between the block and the joist webs.
2. MUST each block be flush with the bottom of each flange (thus, each block 11 7/8" long)? I was hoping to only have to buy 2x12's -- BUT they are only 11 1/2 inches wide (so 3/8" too short).
3. Do I need 1, 2, 3, or 4 blocking spans? (I think 2 will do)
4. Can I stagger each block - to better screw and glue or MUST they be ON LINE (thus requiring me to toenail one side)?
5. Should I ALSO lay 3/4" plywood as a garage "ceiling"? (seems like this will add a LOT of weight and may cause the whole thing to sag.
THANKS IN ADVANCE!
A few questions:
THANKS IN ADVANCE!
