1 - 7 of 7 Posts
I have a blockage and don't know how to clear it. From the pictures I've uploaded, I will explain what is happening. On the right side, water from the washtub builds up and is extremely slow to drain. If you put a plunger on it, it will actually back up the stack that is on the left side. The stack on the right side is coming down the kitchen sink. near the top of this stack there is an auto-vent, so air isn't getting trapped. At some point after the two pipes join and go into the floor, there is a blockage. From the looks of the PVC pipe joins, this wasn't assembled by a professional. I've tried expensive pipe chemical cleaners with no such luck. how can I clear this line? Thanks.
TC
Retired Moderator
Obviously you will need to rod that out with a small rodder.---I would cut the upright and rod from the open pipe just above the T--then add a Y with a cap to repair it.
A rubber Fernco fitting might be good for testing--then glue in the clean out Y after you know that the
line is clear.
The clean out that the original owner installed is a T and would be a pain to attempt to use.--Mike--
Thanks Mike.
Just a few follow up questions.
Can I do this with a manual snake, or will I need to rent an electric one to do it?
Also, after the pipes joins into one, and goes into the concrete floor, do you think the pike goes straight down much further, or will there be a 90 angle or something like that? (Just want to see what I will have to encounter when I snake it.) Thanks.
TC
Retired Moderator
That's very close to the wall---there is a concrete footing under the wall--so-there is likely another bend as soon as you get below the floor.
A hand rodder (maybe one that hooks onto your drill?) should do----Mike--
ok. I just googled "electric drill drain cleaner." Those things cost about $500. I guess I'll have to rent one. This drain clogged up about four years ago. Could it be possible that tree roots are causing the problem since there are trees on the property? When the bathroom sink, toilet, or shower drain water, there is no problem. I'm assuming the problem is between the main pipe out and the laundry tub drain. Agree?
TC
Retired Moderator
You don't need one of the fancy rodders-----for very little money you can buy a rodder that attaches to your own drill---$20 or so----I doubt if tree roots have any bearing on that drain----the pipe runs from where you see it over to the main stack---
My guess? To many bends--shallow pitch and to small a pipe--along with improper venting.
Keep it rodded as needed and you will be fine---fixing it right means opening the floor.
---Mike----
1 - 7 of 7 Posts
