This is the pipe that enters the house. It should eventually be attached to the well. It was left stubbed out by the plumbers but broken off by someone. The pipe in the ground is just a marker. It's not connected to anything. That's the pipe that was broken. The pipe is broken pretty far in the hole. What kind of concrete work would be necessary to be able to glue a coupling to it? Also, there's some dried stucco in there. I don't know how to get it out other than cutting the pipe from the inside, which would require cutting through drywall. Is there a way to suction it out?
