Hi everyone! I have a question about my basement walls. Do you put plastic against the block walls before studding out or not. I put some on one wall and it caused water to form on the outside of the plastic, which I think would get inside my studded wall after it is finished. I took the plastic off and the wall is dry now. So I am confused I have 2 coats of Drylock on all block walls. Do I even need plastic, cause it seems it is going to cause more trouble, Thanks!
