1 - 20 of 38 Posts
I have a gas fired Burnham Hydronics boiler. I am going to bleed the radiators as the first floor is not heating up like it used to. I have a two story house with the boiler in the basement. I know to use the key, release air until water starts to come out. But I don't know how much water to add to the system after doing this. Also, do I do this with the heat turned so low it is off? And, does it make any difference which floor I bleed first? Thanks in advance for your help. This site is great. Have always gotten first rate suggestions!
· Master General ReEngineer
Ayuh,.... Somewhere, you've got a water feed valve to the system,...
It should have an Auto-feed valve that holds yer system to 12 psi, minimum...
How about some pictures of the near boiler plumbing, pumps, valves, etc..??
There should also be a Temp/ pressure gauge,... What's it say,..??
Yer system flows in 1 direction, from the top of the boiler to it's bottom,...
Bleed the system in the same direction, 'n flows...
Hot, or cold...
There is different preferences on the rules for removing air. Lower water pressures allows the diffused air bubbles to emerge for bleeding but if it's set too low, your top rads will start sucking in air when you try to bleed them.
The pump "on or off" is a matter for debate.
I have more consistant success with rad bleeding with the pump off and at least 5 more psi than it takes to get the water to the top of the system but it depends on whether the bleed valves are truely the highest point on the run. 12 to 15 PSI should be enough for yours.
You will only need to replace the water that escaped in the bleeding if you normally keep the inlet water feed valve to the boiler off. It just involves turning the inlet feed valve on for a moment. Your pressure reducing valve will control the volume.
If it's normally left open then the system will refill itself as needed.
Rad bleeding with the pump "on" is done from the bottom to the top.
Rad bleeding when the pump "off" can be done either way.
· In Loving Memory
Bleed bottom to top. After doing so, also drain the expansion tank, as it may be full and the rads were acting as the expansion tank.
· Retired Moderator
If the line has its own pump---consider the possibility that the pump is shot----Bleed first---if that doesn't fix the problem---check that pump.
Discussion Starter · #6 · (Edited)
I've been hesitant to bleed the radiators because of the refilling part of the process. If I only let out a tiny bit of water with each
radiator can I bleed without refilling? There are so many pipes leading in and out. Most have orange levers which seem to lead to the pipes feeding the radiators - they are going in the direction of the pipes which I think means they are open. One pipe leading in has blue levers - these levers are not positioned in the direction of the pipes which I take it to mean closed. I'm thinking the blue levers I need to turn parallel to the pipes to add water but i don't know why there are two. Also, it looks like they may have been installed strangely, because if you read the lever it has an arrow showing close, but if you were to turn it as the arrow shows, you would actually be turning the lever so that it is in line with the pipe, which I have always thought meant open.
If the boiler's water feed is open, then the boiler will automatically refill any bleeding you do if the pressure reducing valve is working... The boiler water feed valve will be on the same line as the vaccum breaker and pressure reducing valve.
If the handle on that valve lines up with pipe, it's open, if it's perpendicular to the pipe, it's closed.
Discussion Starter · #9 ·
boiler photos
Here's the boiler. I added a close up of the blue lever so you can read the writing about before the flow, close etc. If a crucial pic is missing I can download more. Hope this is useful.
I see the vaccum breaker and a couple of blue valves shut off below it and up by the ceiling. That would usually be the incoming line. Normally I'd just get you to open up both of them but since I can't see a pressure reducer on that line, don't touch anything yet.
Are you on a city water supply?
Can you take a photo of that line from a different angle?
Discussion Starter · #11 · (Edited)
Additional Pics of boiler with water source included
These are taken from where the water comes into the house, along the line, and to the boiler. With an overall which I hope helps. Yikes, they are all sideways. Will try to post right way up.
Discussion Starter · #12 · (Edited)
Additional boiler pics from source to boiler - ignore these all photos posted next
Here are some photos beginning where the water supply comes into the house proceeding along the line to the boiler. Ignore these too as one of the pics us upside down
· Retired Moderator
I'm going to ask one question--how old is the pump?
Do you hear gurgling or any other sign that you have air in the pipes?--Okay that's two---
Now I'm out of here----
· Retired Moderator
I'm not a boiler guy--the others answering you are--so I'll stay in the background and watch--
I have two pumps on my system---they have a life of about 12 to 14 years before the impellers are worn away---
I also have a pressure/feed valve on mine---so I can't add much---good luck----you are in good hands already.
· In Loving Memory
The blue handled valve near the boiler is your manual water feed valve. You'll also need to open the blue handle valve up at the ceiling.
OK.. These old eyes can't see a pressure reducing valve on your boiler system. That's a first for me inside city limits. That means you have to manually replace the water you loose in bleeding the rad's. You will have to carefully watch your pressure guage while filling to not over pressurize your system.
As others have pointed out..Both blue valves will need to be cracked open to do this.
Discussion Starter · #19 ·
Going to give it a try - please review my plan - does it seem alright?
Okay, so I am going to do this:
1. Put thermostat on 55, so the system is off.
2. Insert key in radiator, turn slightly, let air escape until water starts to come out. Turn key back.
3. Do this to all radiators on ground floor.
4. Go downstairs to boiler and look at gauge.
5. If it is not at 12 - 15 lbs or 25 - 30 feet, I will open both blue valves.
6. Keep eyes on gauge and close valves when they reach the numbers above.
I have a photo of the gauge as it is now (included in first group posted). My plan is to fill it until it looks the same.
Is this plan right?
Heat has been on all day and it has only gone from 58 to 63.5 degrees on the main floor (it's 66.7 upstairs) - I hope this works. Fingers crossed. I will wait and do tomorrow after hearing back from this forum. Thanks!!!
1 - 20 of 38 Posts
