1 - 20 of 20 Posts
I originally had louvered bifold doors on my washer/dryer closet that were destroyed in a flood.
The framed opening is 96.5 in wide. Originally the doors consisted of 2 sets of either 3 -16 in panels or 4- 12 in panels.
Can 3 standard doors of 2- 16 in panels or 4 standard doors of 2- 12 inch panels be disassembled and by adding hinges be made into the width I need.
The other alternative would be to purchase individual panels and the necessary hardware and make my own but I have not been able to find the panels locally.
Thank you in advance for your input.
· retired framer
Rough opening should have been 97 1/4. That allows drywall or 1/2" trim on both sides.
Three panel could be made to work but would take a little fiddling with hardware because the 3rd panel would not be tied to the track
So I would be looking for the four panels of 12? and just buy the sets, they will have the hinges on the back side. You just have to add the joining hinges and inset them into the edge of the doors so you are not adding them to the face.
So you originally had a post in the center, and two sets of doors, approximately 48" wide for each of the two sets. And you want to replace that with one set of doors, 96" wide. Is that right ?
I had a similar application a while back. I concluded that I adding two sets of doors together was not going to work well. There are not many door sets that wide, but there are a few, such as these:
https://www.doornmore.com/door-configuration/bifold-doors/filter/4-panel-bifold.html
Also, Johnson makes some interesting hardware:
https://johnsonhardware.com/1601-full-access-bi-fold-door-hardware
Thank you for your reply.
There was no center post. Just 2 doors with I suspect were each made up of 4- 12 in panels.
It's been a few years so I don't really remember , it might have been 3 -16 in panels on each door.
Which ever it was they worked well for 43 years.
It would seem that buying 2 -48 in assemblies and hinging each set together would work.
I was hoping to find someone on this forum that had successfully done this or has tried it and found it wouldn't work.
· retired framer
I found some one that makes them
https://landquist.com/bifold.asp
· Naildriver
I did not know Johnson had such an array of bifold, pocket, etc. door accessories until I had to order a set of 1700 hardware last night to compliment what was already on another door. (New install, missing hardware, goofy supplier). For me, the old days of drilling holes in the top and bottom of bifolds is OVER. It only weakens the wood and will eventually fail.
For the record, I had bifolds on my washer/dryer for about 1 cycle then they went into the basement cause they were so awful to use.
I like your horizontal blinds much better. I'd look at vertical blinds if you've got kidos that'd wreck the mini-blinds.
Check the clearance just inside the laundry area where the door will go. The multi-panel folding doors have a choice of models some having the stack of panels centered under the track when fully open versus opening outwards.
Reactions: Nealtw
· retired framer
The ones I saw while looking last night actually WERE hung from rollers, almost like a shower door. Not tandem like a pocket door.
Yeah, the doubles would hold them out when you to open them.
I like the idea of the roller in the middle of the door but the one against the jam would need a track going at 90* into the closet.
But knobs or handles wood screw that up.
Discussion Starter · #16 ·
I appreciate the input from each of you. I believe I now have a good idea of the options I have open to me. The one quote I have been able to obtain for providing and installing doors on 5 closets gave me no satisfactory options either in the type or quality of doors proposed. The bypass doors proposed for the washer/dryer closet would not even work.
Discussion Starter · #17 ·
You all are light years above me I'm experience and knowledge but please indulge me while I ask what I hope is a simple question regardless of whether it is something you would do.
I'm retired and am doing all the work to restore our house that was destroyed with 32 in of water in a flood. I'm doing this on a limited budget and must look at every opportunity to save money.
Having said that, this is the question I have.
Can I purchase 3 sets of 32 in bifold doors, disassembled them and reassemble them into 2 doors of 3- 16 in panels to fill the 96 in opening?
I expect I would need a new rail and some hinges.
Thank you.
If you are talking about like off the shelf bi-folds, I think it wouldn't work very well, but if you replaced the pins (stationary end) of the center fold section with an extra slide pivot (opening side) it might work. I suspect that center section would be pretty wonky since it didn't have a pivot point anymore - I imagine it'd keep tilting over and coming out of the track.
· retired framer
I think the bigger problem is the weight of the door but yes it would need 2 of whatever to keep it in track. One on the end and one on the center join.
... I like the idea of the roller in the middle of the door but the one against the jam would need a track going at 90* into the closet..
When the roller is in the middle, then the door panel against the jamb is narrower and still has a pivot or hinge (like a regular bifold door) instead of a roller.
Reactions: Nealtw
1 - 20 of 20 Posts
