If I have a few screws when I drove into the wood they spins probably due to driver torque set too high now they can't be tightened.
Normally I would just use longer screws but in this case the wood is 1x and behind that is concrete block so I can't use longer screws unless I drill holes in the concrete.
Will inserting a toothpick work or do I need to patch wood filler into the screw holes let dry and try again?
