I want to make a DIY fresh cold water tap in my kitchen using one of those filter kits, but I'd like this water to come out cold. So what I'm thinking of doing is adding a bar fridge to the equation (I'd probably put it in the crawlspace) and in this fridge would be a holding tank. The water would pass through the filters outside the fridge, enter through a penetration I would make in the fridge, enter on the top of the tank, and another pipe with exit from the bottom and go up to the kitchen.
If not done properly this could be a huge disaster, is there any proper way to get something like this done? I need something that can withstand a constant 100PSI of pressure or so. I was thinking of using a length of 4 inch ABS pipe with two ends but not sure how to make the pipes enter/exit, and not sure if that is even designed for pressure application (thinking more about the glue joints). Also not sure if this would be rated for potable water applications given it's made for crap to flow on, not fresh water.
I'm thinking maybe an RV tank? Probably too big though... needs to fit in a small fridge.
What about if I make something out of copper pipe, think it would hold if I solder it well enough? I'd probably run an air pressure test overnight to check for any leaks after I've made it. I'm thinking I'd use some 4 inch copper pipe with two end caps, basically. I think I recall seeing copper drainage pipe at HD so it is available.
