Plumbing Pros--
Would like to add a Hot Water line to the exterior of my house... Looking at the areas where I could "Tee" into an existing Hot Water line, it "seems" my best bet is at or near the Water Heater...
The two options my non-plumbing mind see are to (Option 1) "Tee" into Hot Water line between the water heater and wall, then run the line through the exterior of the garage... (Option 2) Cut an access panel in the drywall, just above or below where the Hot Water line enters the wall... "Tee" into the CPVC in the wall, run it up through the header and outside through the soffit...
What would you recommend??? It is probably a 40-50' run of pipe once I exit the wall by the garage???
I've thought about insulating the pipe and running through the soffit to the back of the house... I've thought about running through the attic, but do not like the idea of water pipe above our ceilings (even though this would probably be the easiest run...
Thoughts???
Thanks much and TIA
Roger V
Thoughts???
Thanks much and TIA
Roger V
