We are in the midst of my hardwood flooring project. A few questions have came up.
1. What's the best way to do the transition from living room to dining room in picture one. We do have a T.
2. This is the threshold at the front entry way, how should we do this so the flooring ticks under it?
· Retired Moderator
A little more info please--
How thick is the hardwood?
Why a transition into the dining room? Why not just continue?
That adjustable threshold is rather short---will it need to be raised and the door cut?
Also I didn't realize I'd need to cut the front entry door. The hardwood will still slide easily with the hardwood installed. So your saying I need to cut into it? I could use my oscillating tool to do so. I used it to undercut the drywall so I wouldn't need quarter round at the baseboards.
· Retired Moderator
Usually the entry door will be so close to the new floor that it will not clear a floor mat--so often, the thresh is raised and the door cut----
If the sheet goods floor is lower than the hardwood---a reducer can be made from a piece of hardwood---round over the edge with a router--cut a notch on the back--and overlap the sheet goods.
