All,
I'm looking to make my downstairs family room into a theatre/media room/hangout area for the kids. At one end of the room is a brick fireplace that covers the whole wall. I'm looking at using this wall as my screen wall in a front projection setup. Wondering if I can get some opinions on the best way to build a false wall to cover/hide/deal with the fireplace without doing any permanent damage to it (in case the next owners want it for whatever reason).
The room is 19x12 give or take an inch. The hearth currently extends 10" into the room. The wall is about 50/50 above and below grade, as this is in the lower level of the house.
The two options I had thought of are:
If I chose option 1, would I need any vapor barrier or insulation between the brick and the wall?
Pic of the wall is below.
Thanks,
Mike
- Build the false wall up against the fireplace, following the general contour of the hearth. This would allow me to extend the hearth section out a bit and add a seat there if needed for additional capacity. I'd fasten the wall to the floor, ceiling and side walls in order to protect the brick.
- Build the wall out in front of the fireplace completely and just screen it off.
Thanks,
Mike
