1 - 13 of 13 Posts
Power Gen/RS Engineer
I'm just curious. What do the pro's think is the best way to attach rigid foam insulation boards to a concrete foundation wall?
TIA and TTFN,
Jimmy
I'm not a pro, but around where I live, they use stick clips. A stick clip has a base that you bond to the foundation wall and a pin that sticks out. You impale the insulation onto those pins and then push the washers onto those pins to hold the insulation in place.
actually the best way is to hire someone to hold it in palce forever
If you just want ad space pay for it and don't waste our time. This site is for constructive advise. Yours wasn't
They make special adhesive for foam board that I have seen magazine articles recommend it. They say to use horizontal lines of glue the width of the boards.
I like the idea of stick clips. If you ever had mice or bugs get behind the foam, you could pull off the foam board.
Use the proper adhesive. I've experienced stripping foamboard off foundation walls that was attached with adhesive and I can verify it works very well.
1 - 13 of 13 Posts
