Hi,
New to this forum .
Just got my new security camera survillence kit and I would like to install some of the cameras on the outside of my home. I have a general Idea of the locations on where the camera's will be placed.
I would like to know what would be the best way to get the ethernet cables from outside to the inside to my home. My home is brand new and is a typical wood frame construction. I have checked with the builder and he said that that the outside studs are 2x6.
* what kind of drill bit should I use? I have drywall on the inside and OSB sheathing + some kind of cement/wood siding on the outside.
* should I drill through the studs or through the OSB + insulation + drywall.
* what kind of sealant I should be using. ?
* would I have any issues with the outside wall insulation?
* should I drill from the outside - in or inside-out?
any other suggesstion will be highly appreciated.
New to this forum .
