I plan on gutting my 1961 bathroom this spring. The vanity drain pipes in the wall are galvanized and obviously I will be replacing with PVC. It connects to cast iron that is in good condition.
I have a choice as to how to handle this and wonder which is the better way:
Option A is to cut the galvanized where indicated in the picture and use a shielded coupler to connect new PVC to the that last little bit of galvanized. Downside to this option is it still leaves some galvanized pipe and it would be better to have it gone.
Option B is to attempt to unscrew the galvanized from the CI, then use a PVC male threaded adapter screwed into the CI. This gets rid of all CI, but I'm a little nervous about attempting to unscrew the existing pipe from the CI. Not sure how difficult it will be. I don't have a pipe wrench but will borrow or buy one. Main thing I'm worried about is damaging the threads making it difficult or impossible to screw in the PVC male threaded piece.
This is a double vanity so there are 2 places where I need to do this but both are the same issue. I do have plenty of room to work as all the plumbing is exposed in the basement.
