Hello all,
I'm working on building an outdoor movie theater at my house. I have everything pretty well ready, but I'm wondering if I'm going to run into an issue.
I want to attach the screen to a PVC pipe and mount the PVC pipe on the side of my house, directly under a second floor eave. Inside the PVC pipe I have a tubular motor, attached to the bracket housing that will in turn rotate the PVC pipe, which in turn either lowers the projection screen or retracts it and wraps the screen around the pipe for storage.
The screen will be 100"x178", which requires a minimum of 15' of pipe. I currently have two 8' 1-1/12" pieces of PVC schedule 40 with a coupler to join them.
My question is, what level of sag can I expect in this pipe over this span? The screen will weigh about 8.5 pounds total on the pipe, and the pipe will only be able to be supported on the ends.
Unfortunately I don't think I can support the pipe in the middle and still allow it to rotate and wrap the screen around it. Would I be better of using a 10' piece and a 6' piece, to move the joined section slightly off-center?
Anyone have any ideas on the level of sag, and if it's too great of a level, an idea for a different kind of pipe I could use over this distance to minimize the sag? It can't be too heavy of a pipe since it's going to be connected to the side of my house and needs to be 1-1/2" OD (1-3/8" ID) in order to be compatible with my tubular motor.
Thanks!
Thanks!
