The question: I had a structural engineer come out to the house and examine our second floor which is sagging. He determined that we need to install a load-bearing beam. He recommended the beam be composed of three 2x12s and that the beam rest on supports with a direct load path to the foundation. (The span is around 13') My question is in how to support this beam. Since the total thickness of the beam will be 4.5", what's the best practice for constructing the jack studs? If it were only two 2x12s, I'd just sandwich a piece of 1/2" plywood between them and end up with 3.5" total, which would fit perfectly on top of 2x4 jack studs. The extra 1" is throwing me... Thoughts?
Background: Our house is balloon framed and the floor joists are notched to "hang" off ledger boards or rest on top of bearing walls. The previous owner removed one of these walls on the first floor. The joists from two adjacent second floor rooms met on top of that wall. When the wall was removed, there was nothing left to support the ends of the joists, so naturally, those ends fell downward. The guy scabbed the joists together, but didn't level the floors before doing so. The result is a sloping floor in each of the two rooms. Did I mention that there's a second floor wall sitting right on top of where the joists met? Deflection much? I've attached my wonderful drawings for clarification. :laughing:
