1 - 20 of 32 Posts
Hi Guys,
I have a new 1070 sq ft 2nd floor addition that I am looking to add air conditioning to in the future. Does anyone have any reccomendations for what type of system to go with? There is plenty of attic space. I am open to thoughts or suggestions.
Thanks,
Pat
· In Loving Memory
First determine what size you will need. Will you be running the electric for the outdoor unit through the attic also.
You need to get a heat loss/gain calc done, room by room.
Keep the equipment out of the attic; additions can be served efficiently with mini-splits. Attic system is bad for efficiency and sucks for whoever has to service the air handler.
If you want ducted system, at least put the air handler in a closet.
Unless you live somewhere where it actually gets cold during the winter (ie. Daytime highs below freezing for months) then a mini split heat pump would probably be best. There's a very wide variety of indie units to choose from.
Use http://www.loadcalc.net/ for the loadcalc. Is fairly basic, so easier to use, but covers enough of the basics to get you by.
Cheers!
PS. Your addition is bigger then my house.....
· Retired Moderator
A brief description of the construction (windows/wall insulation/attic insulation)
would be helpful, as well as what heating/cooling system serves the existing home--
You are on Long Island---so you have some cold winters--but how hot does it get in the summer?
All new Marvin Integrity double hung windows. No insulation at the moment but the 2x4 walls will have R 13 and the ceilings will have a R 49. The heating will eventually be a gas furnace with hot water radiant heat.
Average highs in the winter on Long Island are in the upper 30's and average highs in the summer are in the mid 80's.
Why don't you put in central A/c if you're putting in a furnace and ductwork?
The size of the unit will be calculated for you by the company doing the installation.
I'm not putting a furance in and I will be doing the install of the air conditioning...
This is what you wrote:
"The heating will eventually be a gas furnace with hot water radiant heat."
What did you mean?
HVAC should be part of the planning process, not an after-thought.
Also, it's not only a question of room, a duct system has to be designed from scratch, bottom up; even if you had the room, you wouldn't be able to just add a few runs and get it to work right.
Your best option is likely a multi-head mini-split system. New ones if sized right can heat down to -20c, and you can add some electric baseboard for emergency breakdowns or extreme cold.
You could also do something with natural gas wall heaters.
Hot water radiant would be pricey.
Your codes down there must be pretty lax, because R13 is piss poor by today's standards. Up here a 30 year old house can be 2x4, r11 to r13.
Here it's all 2x6, r19 and extra insulation gets put on the outside to meet code.
I'm curious how someone who asking about the A/C options, is going to install systems they're totally unfamiliar with.
Discussion Starter · #15 ·
Because I have never installed one of these systems before. I never built a house before but I did it with me and one othet guy and I'm proud of it. Sorry for trying to try to inquire about information.
· Retired Moderator
Nice looking house----
Pardon me for bawling out our members----Geez gang---this fellow is looking for answers, solutions to a need----did he really need to be criticized for calling a boiler a furnace?
I'm not an HVAC guy, but at least I was able to be somewhat helpful----
Put away the grumpy pills and offer this fellow a simple solution---RANT OVER--Mike--
A/C installation requires a certain experience, and test equipment. If you have that, you can do the job. You haven't expressed that experience so far.
The last thing you want, is to buy all this A/c stuff and not be able to install it.
Reactions: oh'mike
HVAC stuff is engineered on site, it's not like putting in a light fixture. Lots of stuff to mess up.
Leave sizing and installation to the pros.
I know a lot about this stuff; load calculations, refrigeration theory, matching components but even I wouldn't attempt to do something like that myself.
Who will warranty it?
Discussion Starter · #19 ·
All I was asking for was information about different types of ac systems. Now I am getting interogated about installing this stuff just like I did with building the house from scratch, just like I did with installing the electrical service coming into the house...
1 - 20 of 32 Posts
