So we're getting close to the point of Tiling over our brick fireplace. Yesterday we applied some mortar to a few of the crevices (not the old grout joints) and the NEWLY-applied mortar was a bit sandy and flakey in spots.
Someone told us: "Mortar is not meant to be used as a skim coat. I suspect, too much sand in the areas that flaked. Brush off with a wire brush any loose mortar. Apply a cement based patching/embossing filling compound and smooth for your tile install. You might have to apply several coats to achieve desired smoothness. Speedfinish is one such compound:
SpeedFinish 10 lb. Patching and Finishing Compound-SF10 at The Home Depot "
So my question is more of what do you think of that opinion? We should NOT use basic mortar compound to fill in the grout lines? We'll be using a Thinset with a Latex Adhesive as the base for our Tiles.
so confused... Thanks in advance.
