1 - 10 of 10 Posts
I'm about to purchase a rental property. During the inspection, the inspector found bees coming out of the block wall where some conduit enters. I'm guessing they are honey bees. I've read that the honey combs should be removed, so the bees will not come back. I will not be able to do that in this case without destroying the wall. How can I get rid of the bees? Should I try exterminating them or call a local bee farmer/club to see if they want to remove them with traps?
Is this wall just exposed blocks on both sides. If yes, then a couple of thousand and a large section of wall could be removed along with the comb, repair and done. If this wall is finished on the inside or other than a plain wall on the outside, it will cost more.
IMO, "as is" purchases usually have a lot more to discover than a few bees. Was this inspector one you selected or one the real estate agent selected. The latter owes his/her continued income to that agency and NOT you. Home sales usually come with a full disclosure form that will give you some assurance as to the condition. "As is" properties do not.
Be sure the title is clear and not a "quit claim deed" and anticipate many more hidden expenses.
Bud
Discussion Starter · #6 ·
I believe it is finished on the inside. I'm trying to get away from having to demo any of the wall. Is there a way to just use insecticide on the old comb, so they do not return? Is there any way to determine how large the comb is (infrared camera)?
Google "bee keeping supply" for your town. Call the shop and tell them you think you have honey bees and would like it removed. They'll either come out to remove it, or they'll give you a phone number of someone who will. Bee packages here in denver are running $130/package, so usually there are people who will do it for free. I would still get in to remove the comb, as it attracts other pests such as mice, other insects and more gross and smelly are various larvae which will take over.
You can go the insecticide route, but why would you when all you you'd need to do is make a few a phone calls and someone would come to you and help remove them?
· Civil Engineer
Ditto 1acre. Any insecticide capable of permanently killing the bee colony may be toxic to humans, and what do you have against honeybees? We had a friend who purchased a house with several thousand honeybees in the walls, they were removed by a beekeeper for a relatively low cost, the holes sealed up, and they never came back. Got some honey out of it too.
Discussion Starter · #9 ·
The insecticide was more of a preventive measure. I really don't want to kill any bees. I wasn't sure if there is some type of repellent that could be applied in the crevice that would keep bees from setting up shop again.
If the blocks are hollow and not filled with concrete, which is what it sounds like, then any honey left in there will be accessible from anywhere around the foundation. That means ants and other unwanted insects will simply enter at some other point and walk around to collect their dinner. Then, if honey is like other organic materials, it will eventually turn to mold and again, the connected nature of the block walls will feed that air into the building.
This is something that needs to be fixed before it becomes a bigger problem.
Bud
1 - 10 of 10 Posts
