I am helping someone diagnose and fix their Beckett oil burner with Utica 300W boiler. It has a A2va-7116, Suntec 2460GU single-stage pump. The motor, a Beckett Model No. SA55GYKPA-5733 motor 2.0 Amps RMP 3450 1/7HP motor with Honeywell electronics turns on and spins fine. Motor seems fine. The owner of the heating system opened the line near the tank and checked the filter, then closed up the line. So I suggested bleeding the lines. We did one short bleed, then took out of reset. I have not yet checked spark of electrodes. I am a competent engineer, I just have little experience as I grew up with a gas heater, not oil. So I have some knowledge of electronics and general things and I understand full well dielectric breakdown if I need to test the electrodes. I think the electrodes are probably fine. I know the heater had a slight delay on start last year - perhaps transformer, I don't know yet.
One quick question - I will bleed a little more - I think there might still be air in the oil input. But if the pump turns on - and not enough spark - do I need to let the oil out somehow? That's all I want to know right now before I start cleaing stuff like Oil nozzle, or a full blowdown or continue testing stuff.
I realize that there a lot of tools that a technician uses and I might have to buy some of them.
Thank you.
Thank you.
