1 - 6 of 6 Posts
I need to install bead boards (5" wide) tong/grove over drywall that has metal studs. Suggestions for best method would be appreciated. Several rooms; probably 150 boards that will be 48" high with a chair rail and base added.
Thanks.
Construction adhesive and finish nails shot into the tongue until it sets. Occassional face nailing as needed.
Ron
Discussion Starter · #6 ·
Thank you all for your suggestions. The staples and adhesive is what I plan to use, with some screws into the metal studs periodically. The chair rail and base should hold things together pretty well.
Thank you again. :thumbsup:
1 - 6 of 6 Posts
