1 - 20 of 27 Posts
· Premium Member
Discussion Starter · #6 ·
We heat with wood, so we cut and burn 6..10 full cords of wood each year, depending how many months of snow (7..9 months).
Depending if the logs are green or dry and diameter (6..14 inch), we load 2..8 foot lengths in the truck and then cut to size at home for 2..3 hours per day.
So, wondering if you think they'd be good for cutting a truck load and for cutting 2..3 hours per day.
Thanks for all your good feedback.
With the 5aH battery in ours it was able to tackle nearly our entire annual clean up + a bunch of extra cuts. With "two leds" on it we fully chopped into woodstove size chunks the big fallen spruce tree in video, cutting to woodstove size a number of 8-10' sections of 8"+ diam birch trunks, downing/debranching/and cutting a ton of willow into longer firepit size, and taking down a few misbehaving branches and cutting those down for firepit or woodstove.
I think the 5ah can easily handle 2-3 hours a day. We have the ... 3.5ah type as well, but we've never tried it in the saw. I did use the smaller one in the blower and it lasted a couple hours, more than long enough to blow off both driveways - I don't think the blower takes as much power as the chainsaw though.
· Premium Member
Discussion Starter · #10 ·
Thanks, looks good :)
Thinking I'll have to get something bigger for our needs, but good to know they are dependable and cut well. :smile:
I have an EGO with a 16" bar. It has a 54 volt battery pack. It works really well. It's quiet, has a narrower chain than what's on my Stihl gas powered saw. I'm cleaning up a lot of dead ash trees in my woods. I can cut for about an hour and a half before I run the battery down. Now this includes time in between cuts walking to the next tree. But I was pleasantly surprised on how well it works. I also have their handheld blower which takes the same battery. It also works great for cleaning up the shop and flowerbeds.
Mike Hawkins
· Premium Member
Discussion Starter · #17 ·
https://www.homedepot.com/p/ECHO-16...ery-and-Charger-Included-CCS-58V4AH/205566014
Not available at HomeDepot, so got it through Amazon for $370.
Got it yesterday, used it today.
Limbed and cut up a 10 inch lodgepole pine that the winds had blown over this winter.
Went through it like butter. Variable speed is nice for limbing.
3 bars on battery gauge when done.
I like how you can save battery by releasing trigger between cuts.
Bar and Oregon chain are thinner than Stihl, etc.
Chain loosens up, but may be because it's new.
14.4 pounds w/bar and oil. Wifey said it's too heavy for her, but we were on a slope, not solid footing, so might be better in log cradle.
Going to keep it in jeep and truck when 4-wheeling in case of trees blocking path.
Hopefully the loose chain thing is temp, that's a dangerous thing... I'd wear armor for a while until you're sure it's staying tight :p
A new chain on any saw will loosen up over the first few uses. And “staying tight” is a relative term. Too tight and it won’t turn properly and can overheat the saw; too loose and you get chain slap on the front of the bar and increased potential that it will jump the rails. And the saw will come with an instruction book that will tell you how to properly adjust the chain. In general, loose enough to turn with gloved hand.....but tight enough so that when you pull the chain directly away from the bar the drive bar tangs come about 1/4 of their length out of the groove (for a bar without a nose sprocket, tighter for one with) Or better, google it!!
1 - 20 of 27 Posts
