1 - 18 of 18 Posts
Concrete slab. It's sinking in how much I just screwed myself by being inpatient. I think the only way would be to start from the other side of the wall.
- Yes, cut the drywall from the other side (cut it professionally, not sloppily), and save the drywall piece.
- Locate the nut that holds the end of the shoe. Disconnect using an adjustable wrench. The nut must have a nylon washer.
- Reverse the process with the new shoe. Finish the wall or cover the hole for future use.
It looks like you may have some cracks in the enamel and even already some rust stipples. Dunno how long the tub itself will last, even if you can replace the shoe. We had a thread recently about someone who had a rusty-ass tub and was trying to fix the damaged areas with Bondo.
Discussion Starter · #12 ·
I saw that thread, interesting one to say the least.
I see what looks to be rust as well, but this is fiberglass.
Discussion Starter · #15 ·
Well as always, this has turned into something more than it should have. I have removed the bathtub and will either be installing a shower pan from Delta or I'm looking at this Kerdi kit which would be used for tiling everything from shower floor to walls.
Apparently for shower only units the plumbing is supposed to be two inch. Also, do showers not use drain shoes?
1 - 18 of 18 Posts
