I just remodeled my bath and installed a new Panasonic fan. Everything was fine until I tried to install the vanity top light and found out that there was to electricity at the wall outlet or the black and white wires coming out the wall and connected to the light. All pictures of current wiring and set up are attached.
Wall outlet has a GFCI, and three switches. One side is for the fan/light and this the other switch controls the vanity light and this is the switch that is not working. When I tried to test it, there is no electricity signal from the outlet or within the wall. There is no electricity whatsoever going to this side and the vanity top light. There were not changes in wiring during the remodel. All I did was to update the older electrical outlets with the more modern outlets and install the new fan, which works fine. The left wall switch contrlols both the fan and light at the same time, which is fine. its the right switch that contols the vanity top light without any activity.
Please help since this is the only thing our family needs to have a working bathroo. Thank you so much.
