While remodeling the kids bathroom I tried to use the bathroom outlet for my drill but it ran at extreme rpm and I could see electrical arcs in the motor.Figured my drill finally went bad. Later I replaced the outlet with a GFCI but after about 5 minutes it started to smoke and it blew.Put voltage tester to it and blew the glass fuse to bits all over floor.(son behind me asked if it was supposed to do that). Previous owner had ran the wire to a 220v breaker. This outlet is the only thing on this circuit.
I need some help on using this wire to power a bathroom fan. I have the non powered wire from the wall switch ran to the new fan but not hooked up. I want to get the power from the receptacle wire once I get a new breaker. How do I hook the wires together at the fan?
From fan- black wire, white wire, ground
From switch- black wire, white wire, ground
From receptacle wire- black wire, white wire, ground
