I have a semi finished basement with full bath and a wet bar previously plumed. Both areas share and adjacent wall. I need to add an exhaust fan to the bathroom and I'm planning on adding two 20 amp GFCI plugs on either side of the sink in wet bar and two 20 amp plugs below counter to run a mini fridge and wine fridge. Both rooms and the rest of the basement (lights, outlets, etc.) are on a single 15 amp breaker.
My plan is to run a dual 20/20 tandem circuit from the main panel to the bath and wet bar. leaving the rest of the basement on the 15 amp circuit. the panel is a 200 amp service with room for 3 more breakers. I wanted to save room by using the 20/20 tandem.
My question is, can I do this safely and is this going to bite me in the as* if and when inspections come through.
My understanding of the 20/20 tandem, is that I can run two 20 amp circuits from one breaker. Is this correct?
with this set up if anything trips both the bath and wet bar will go together, is this correct?
