1 - 7 of 7 Posts
I'm in the process of putting up walls in my new basement bathroom. There will be a tiled shower, the rest of the walls will be paint. Please tell me if I have the process right:
Shower walls will be DuRock coated with Redgard (or is tile backer the thing to use in a shower). The rest of the walls and ceiling will be DensShield painted with mold inhibiting paint.
Is there more I need to do or a better product to use?
The products you mentioned for the shower are used interchangeably. Redguard is mentioned quite a bit as a waterproofing barrier. I've used kerdi myself a few times in the last year. Can't really say one is better then the other. Both are supposed to do the job.
What thickness cement board did you use? Hopefully 1/2".
Ron
I probably mispoke. By "in the process" I mean I'm getting ready to start the walls. Haven't put anything up yet. I also saw a backer called Fiberock that looks to be the same as DenShield. Do you put Redgard or Kerdi over these too?
The only backer I use is cement board with kerdi. Never heard of Fiberock. I'll check on it,just out of curiosity.
Ron
Seems similiar to hardiboard.
· Registered User
Cement backerboard is a good traditional way of doing things. Redguard is ok, Kerdi is great. Either will work just fine. Don't forget to fill the seams with thinset and tape them with backerboard mesh tape....Very important step that DIYers often overlook. In the rest of the room there's no reason you can't use good old green board.
· Registered User
Thanks KC. Is green board OK to use for the ceiling in the shower area?
I just noticed your sig. I know an electrician that always says "the code is the worst job you can do and get away with it"
1 - 7 of 7 Posts
