Hi - I have a bathroom sink that is one piece - counter and sink together. Recently, the overflow tube to the sink came loose. It consisys of a plastic piece glued to the outside of the sink, connected to a rubber hose to the drain pipe. I tried to glue it back, with no luck, since it's being glued to a quartz (i believe) sink. I've attached two pictures of the overflow drain. You can see the pip through the hole. Currently, I have some wood holding the plastic piece in place, but it;s definitely not watertight.
And an added question, can I get some other solution to this problem, such as a piece that goes from the sink side to the outside of the sink, so I don't need to glue it?
Thanks so much.
Thanks so much.
