Beginning a full bathroom remodel where everything will be replaced. Tub, sink, toilet, flooring, upgrade electrical, and replace galv. steel pipe. Most of the details have been worked out, but I'm stuck on what drywall to leave or to rip everything out and put new.
There is alot of cracked/peeling paint at the tops of the wall near the ceiling. Also, above the shower near the ceiling, the drywall looks "wet". It's hard to tell by feel if it's still damp or just cold & got damp previously.
The mirror wall on the left will be mostly removed to have access to plumbing (including vent stack through roof), electrical, and water supply lines. We have different lighting plans, so the current light in the ceiling will need to be patched. Likewise, a bathroom vent fan hasn't been chosen yet, so the existing hole might need to be patched as well. In general, you can see darker areas and some areas that are more glossy vs. matte with fuzz on it.
With a lot of natural light coming in through the window, I'm worried that trying to salvage drywall will require a lot of mudding work to make the new/old undetectable when light goes across it. Additionally, there's the matching of roller texture of old to new. With 8 ft ceilings, a new drywall sheet could go vertical leaving only tapered joints to mud. On the other hand, is ripping everything out creating more work than necessary?
