I'm remodeling a bath, upon demo I found water damage behind the tiled shower stall, located on an exterior wall corner. It seems the original big box builder didn't take the correct steps to ensure a quality job. The insulation in place had no Kraft paper, nor any plastic vapor barrier, it was unfaced insulation with green board and cement board directly attached to the studs.
Now I'm in the rebuilding process, and I keep reading conflicting information regarding insulation, and a vapor barrier for a bathroom.
Conflicting Info Examples
- Use both Kraft paper insulation, and a 6mil poly vapor barrier
- Never use two vapor barriers next to each other, they will create a moisture trap and cause issues
- Inspectors won't allow faced insulation installed, and will require kraft paper removed.
I'm planning on using cement board and re-tiling, but first question, what to do about the insulation and vapor barrier.
Any input regarding the correct/best method to insulate would be appreciated.
Jim
Jim
