1 - 6 of 6 Posts
Installing new fans and there isn’t existing venting in attic to the outside. I’m going to install a vent on the roof and connect insulated pipe to the fans.
Two questions. Can I connect both fan vents together and into the same vent in the roof. Secondly I’ve heard you are supposed to create a “loop” in the insulated pipe. Where do I create the loop? What’s the purpose of it? I’ve heard it’s so condensation doesn’t make its way back or something. Sorry I couldn’t be more specific. A
· retired framer
2 separate vents o the roof and yes, if you go straight up you will get condensation and dripping back down, it's not much so just a little sag in a pipe that will hold a teaspoon of water. It will leave and be replaced the next time you use it. Or run it longer when it is could outside.
No loop, a loop will fill with water and stop the flow.
1 - 6 of 6 Posts
